Case leaking oil?
My 2000 Boxster S just had a new IMS bearing, new RMS, new spark plug tubes, actuator seals, new cam chain tensioners and oil separator. It has 160,000 miles. Brought it home and it's leaking oil too much. The shop believes it is a leak from the case itself. They are totally behind the work, I trust them, and I'm bringing it back.
I just like to know what I can about this. Is this a known issue? Is there something else that could be going wrong here?
The car was leaking a lot of oil when I brought it in. The thought was that was caused by the other issues that were addressed. So either there was still something else that was causing the leak (like the case itself) or something was not put on right (which I think is unlikely).
Old 06-03-2024, 05:27 PM
