-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   P0348 Camshaft Sensor 2 fault (http://forums.pelicanparts.com/boxster-cayman-forum/1165631-p0348-camshaft-sensor-2-fault.html)
987WAM 08-14-2024 11:58 AM
I'm getting a P0348 Camshaft Sensor Bank 2 failure. I'm able to clear it, start the car, and drive. But the next time I start the car it returns. When I check the Camshaft Deviation, I get a steady 2.1719 on Bank 1 and a zero on Bank 2. Does this indicate a bad Camshaft Position sensor or a bad camshaft deviation solenoid. After writing this I feel like I have enough information to be dangerous!!!
CarGuyNeil 08-14-2024 01:31 PM
It sounds like a bad sensor.
Sent from my SM-S928U using Tapatalk
987WAM 08-14-2024 08:44 PM
P0348
Thanks for the quick reply. I ordered the sensor and will report back.
korex 08-19-2024 11:19 PM
Will be waiting to hear from you
stealthn 08-22-2024 01:52 PM
What year and make of car?
987WAM 08-26-2024 02:34 PM
So here is the latest on my issue. One of the wires to the sensor was broken, physically ripped in two places. I have no idea how that could happen. It was difficult to reach, but I did manage to crimp a jumper on it. That made the connection and I was able to clear the code. My concern now is the actual value readings I'm getting. Before, I was getting 2.1719 on Bank 1 and 0 on Bank 2. Now I'm getting 2.0000 on Bank 1 and -0.0313 on Bank 2. I can imagine that my crude jumper is messing up the resistance in the Bank 2 wire, but why would the Bannk1 reading change? Also, could this impact the position solenoid in a way that can damage the engine? BTW is a 2006 Boxster S.
CarGuyNeil 08-26-2024 02:47 PM
Do a proper wire repair and check again. At least you'll have peace of mind that that is not the problem and that you can continue to diagnose if necessary.
tcora 08-28-2024 03:40 AM
My only comment is on the wire damage. Probably not “ripped”, but more likely mouse damaged. Inspect everything else you can see, I’d suggest.
CarGuyNeil 08-28-2024 03:50 AM
Good advice.
987WAM 08-29-2024 12:53 PM
Thanks for the replies. I have to take the trans out to replace the clutch. I think that will give me better access to repair the wire properly. I can only get one hand to it from the top. I wish they made the access hole larger! How does anyone work on these things?
CarGuyNeil 08-29-2024 12:58 PM
You have more access than most vehicles, top, front and bottom. Most vehicles only have top and bottom.
HighBit67 09-02-2024 07:43 PM
Bad sensor
djnolan 09-04-2024 03:41 PM
the wiring harness on the 987 is delicate. The wires are very thin and delicate. I had a broken MAF wire caused by me ripping it when I unplugged the sensor to clean it.
Te repair the wire, I had to undo the wire tie downs so it could be worked on. I soldered and shrink wrapped it.
