2005 Boxster S cooling fan will not turn off.
2005 Boxster S driver's side cooling fan will not turn off.
Retired General Motors electrician with background in electronics.
Working on a friend's Boxster.
Searched threads here but couldn't find an answer.
Had to disconnect battery to stop fan. After tracing wire back, found fuse block under hood on passenger side fender wall; pulled supply wire (12 GA red) to kill fan #2. It originates from firewall bundle so I assume it goes to relay bank.
Pulled all relays (driver's side foot well, trunk relay carrier) but still hot.
We know FAN #1 is a different animal with it's own control unit.
Does the DME control it?
What are we missing?
Thank you.
Old 02-14-2025, 01:12 PM
Discovered that the Fan Control Module in the R wheel well also powers FAN #2 in the L wheel well.
The wire goes back through the wheel well, along the fender, into the dash, back through the firewall all the way to the L wheel well and powers FAN #2. Wow.
Ordered a new module.
Old 02-14-2025, 03:27 PM
