986 Boxter immobiliser fault
Hi I was wondering if anyone could help me with this I’ve had my 2004 986 boxer for a year and it has now got a immobiliser fault code and won’t start or even turn over when I try to start it.I have tried leaving the battery disconnected over night then starting it but still nothing I’ve opened up the immobiliser module and there is some corrosion on the circuit board not sure if there is a chance it could be cleaned up but if not does anybody know anywhere that would be good to get a new one programmed to the car
Old 02-22-2025, 02:27 PM
Try cleaning first. I don't know if you can still buy new ones from Porsche.
Sent from my SM-S938U using Tapatalk
Old 02-22-2025, 02:43 PM
Corrosion means water intrusion, and that is almost always fatal.
https://www.ecudoctors.com/ - send them your ECU, immobilizer and keys.
While that is happening, check the drains under the convertible top to make sure that they are clear.
Tom Coradeschi
03 Boxster
Old 02-23-2025, 04:54 AM
Thanks for the replies I’ve now cleaned it out and fixed the water leak that caused it the car now starts again but windows don’t work and it still doesn’t lock I’m not sure if it’s that has to do with that module or something else what do yous think
Thank you
Old 02-25-2025, 09:20 AM
Power the windows at the window motors to check functionality. You could still have an Immobilizer issue which could be corrected by the recommended ECU Doctor service.
Old 02-25-2025, 09:49 AM
Banned
Try cleaning first.
Old 02-26-2025, 03:02 AM
Porsche's Love-em Live-em
The Immobilizer in my 2003 Boxster was in puddle under the drivers seat. Resulting in nothing. no start, lights etc. working. removed it dried it, Soaked with "Corrosion Block". tooth brush scrubbed the bottom side of circuit board where the visible corrosion was. Corrosion block it again. Dried it very thoroughly with compressed air. including it putting it out in the sun to dry. Reinstalled it and all works but the front and rear trunk elec. locks. Ended by passing the front trunk wire-ring to a push button by the seat. Removed the reat trunk lock latch and all works just not secure rear trunk.
Old 03-12-2025, 06:25 PM
Tags
986 , 986 1999 boxster , 986 electrical issues
