-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Windows not dropping with handles (http://forums.pelicanparts.com/boxster-cayman-forum/1175003-windows-not-dropping-handles.html)
winddude_999 03-10-2025 04:27 PM
My windows aren't dropping in my 2000 boxster(986) when the handles are pulled, this is for both doors:
Here's what I've confirmed so far:
- the micros-switches for both handles work, and pass a continuity test, the exterior one looks brand new.
- the micro-switch in the door latch is worn, but the window drops when it's pressed manually.
- jumping the connector for either door handle micro-switch does not cause the window to drop
I'm wondering where else the fault could be... wiring harness... or is there something else obvious like a fuse I might be missing.
tcora 03-11-2025 03:30 AM
Check the function of the door latch switch by opening and closing the latch, not just by manually pressing the switch.
djnolan 03-11-2025 03:33 AM
On a 987 , clearing codes will clear up some some problems. Not sure about a 986. Do you have access to a scan tool?
Also there is this thread. Rennlist 9x7 window guide: https://rennlist.com/forums/diy-boxster-and-cayman-diy/1284222-replacing-a-9x7-door-lock-actuator-using-a-cheap-vw-part.html
dedyplay 03-11-2025 04:36 AM
You've done thorough troubleshooting. Next steps:
1. Check the wiring harness: Inspect for damage, corrosion, or worn-out connectors between the door handles, door latch, and the window regulator.
2. Fuse and relay: Verify the window regulator fuse (usually in the rear trunk area) and the door window relay (in the instrument panel) are functioning.
3. Window regulator: It's possible the regulator itself is faulty. Check for any signs of wear or damage.
4. Central locking control unit (CLCU): As the CLCU controls the windows, it might be worth checking its connections and functionality.
5. Consult the wiring diagram: Study the diagram to ensure you're not missing any connections or components.
dedyplay 03-11-2025 04:41 AM
If you're still unsure, consider consulting a Porsche specialist or a professional mechanic.
winddude_999 03-11-2025 07:34 AM
- i do need to finish checking the wiring harness.
- pretty sure all the fuses are under the dash? or where in the trunk is the window regulator fuse? although windows drop with the buttons, and window regulator switch
- window regulator seems good, no slack, goes up and down with no issues, door latch drops the window
- CLU - that is my fear.
- any link to a the appropriate wiring diagram?
- that's a good one, you're a funny guy.
tcora 03-12-2025 03:11 AM
Did you do this? My experience is that the switch can be good, but the cam which rotates to depress it can be worn, so the windows don’t drop.
winddude_999 03-12-2025 09:35 AM
Yes, I did, and rebuilt the height of the button / worn cam with layers of shrink wrap. So it's working well now. But the handles aren't dropping the window.
