Transmission screw oil leak
Hello, my transmission have an oil leak. I've cleaned all the cover to find where the oil leak come from, and discover that is from one screw on the right side, you can see in these pics I took:
What is this screw? Do you know is has got seal ring?
Old 02-10-2013, 01:27 PM
Hello again, nobody know what's is this screw? I want to disasembly it to change the seal ring (if it has, of course).
Old 02-11-2013, 04:28 AM
NYC
Maybe a photo with a wider view might help other members identify the plugs. On a Tiptronic there is a plug in that area for the final drive fluid. I really don't know from the photo what it is for. Why don't you get a drain pan and go for it and remove the plug and inspect what you have to do to correct it. JW
Old 02-11-2013, 07:34 AM
Here is a pic to located in a complete transmission. Its manual and 6 speeds.
I'll dran it and loose the screw, but I don't want have a problem inside transmission, I don't know if this screw holds any interior piece. what do you think?
Old 02-11-2013, 02:46 PM
I think its possible a shift lock device, see number 2 in the attached image:
Old 02-11-2013, 03:14 PM
NYC
According to the diagram that you has provided that sure looks like the right bolt and it is close to the shift lever. however to repair the leak i guess you would still have to remove it.
Old 02-11-2013, 03:32 PM
NYC
According to the diagram that you has provided that sure looks like the right bolt and it is close to the shift lever. however to repair the leak i guess you would still have to remove it. Number 1 in you diagram looks like the reverse light switch and these components look to be in the rear section while the photo of the bolts in question seem to be in the front section. Take another look under your vehicle again and see where that switch is in relation to the bolts in question. Here are some more photos.
Old 02-11-2013, 04:30 PM
Thnaks for pics jwgn777. These photos you post, is from a 996 because this screw it's in the opposite side of my boxster transmission. For those people who don't know boxster and 996 differential are differents in both cars, things are in opposite sides.
In the second photo I asumme that is the screw marked with number 40, but there are 2 screw in my transmission, why only appear it one in photo?
To solved this problem IŽll remove the screw, but I thought this screw had an O ring to replace and doesn't appear it in diagram.
Old 02-12-2013, 01:22 AM
NYC
Yes I know they are opposite. It was the only photo that i thought might look like the bolts.
Old 02-12-2013, 05:20 PM
BoxsterGT's Avatar
Porsche Crest
The 2nd photo is not of a 996 trans. Look at the starter location.....
Len
Old 04-17-2025, 01:13 AM
