2001 Boxter S
AC repair/evaporator/foam
Hello Guys.
Recently I replaced the AC evaporator in my car. It was leaking from the first day a bought it. The PO was quoted 3500$ for the fix, and that was one of the reasons he wanted to sale the car. “While I was in there”, as people here in the forum like to say, I cleaned the whole AC system from those Annoying foam flakes, that use to come out of the air vents when the AC was on. I also re-foamed the internal flaps of the air box, to make the flap seal the passages as they suppose to. i have documented the whole process, and prepared some DIY's As I mentioned in my original post (AC question - 986 Forum - for Porsche Boxster Owners and Others) I will be happy to receive any comments. This is the full procedure: Step 1 -Heater removal: https://www.dropbox.com/s/hxb4w0y3incjrcc/step%201%20heater%20core%20removal.pdf Step 2 - Dashboard cover removal https://www.dropbox.com/s/bjsmzjkt7fz4jru/step%202%20Dashboard%20cover%20removal.pdf Step 3 - Evaporator replacement: https://www.dropbox.com/s/wjz9stc83j3wxpe/step%203%20Evaporator%20replacement.pdf
I just had a look at the first installment, and it looks like you've done a great job!
thanks for the hard work and very nice writeup |
heater core leak
Meirschwartz,
I very much appreciate your write-up on changing out the heater core. Very instructive --and timely. I am convinced my 2000 Boxster S has a leak, a very small one, I believe, in the heater core or in the connections to the core because I can smell anti-freeze when the blower is on. It is such a small leak that the coolant level has not changed in over a month of checking the level. Also, I can see no dripping from the drain tube that drains the air plenum. It is a very small leak --but I am afraid it will get bigger --and the smell is annoying. Is there any way I can view the core without disassembling all that stuff in front of the window? |
2001 Boxter S
You will have to compleate step one in order to inspect the heater core. It is not to hard to complete though. |
