-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Speedometer not working!!! (http://forums.pelicanparts.com/boxster-cayman-forum/140315-speedometer-not-working.html)
cintoboxster 12-18-2003 08:21 PM
Everything work on the instrument cluster except the speedometer (analog part does not move, but digital parts lights up but does not count) When the PS2 is hooked up to it and a signal is sent, it works and it also works plugged into another Boxster. My mechanic says it could be the speed sensor...
How do I diagnose this to find out if tha's the real problem and not something else? Where's the speed sensor anyway?
Any input appreciated! Thanks!:D
carlson 09-13-2019 02:25 AM
Did you find the problem? I am having same one with my 98 Boxster.
tedder 09-17-2019 06:20 PM
ummm... that thread was from 2003. not sure you should count on a reply.
Dmitry at Pelican Parts 09-19-2019 01:48 PM
Hello - take a look at the link below to an earlier thread where this is discussed. I would also suggest posting your question in our Boxster specifc forum, 986 Forum.
Speedometer Not Working - 986 Forum - for Porsche Boxster & Cayman Owners
