Brake fluid changing
I need some tips on the changing of brake fluid. My concerns are:
1. Is it possible to perform a gravity -bleed?
2. Is the system split diagonally or front and rear?
3. If I wish to bleed one wheel, is it neccessary to remove any
electrical connection at the A.B.S.? And, how is the A.B.S.
accessable?
Is there anything else I should know beforehand?
Old 10-01-2004, 11:17 AM
You bleed the brakes like any other car. Don't need to touch the ABS unit. Get a helper for the brake pedal or do it yourself with a Motive power bleeder.
Old 10-02-2004, 06:25 AM
