RPM driving range
We recently purchased an "02" Boxster, also have an 87 911 cab. I normally drive the 911 @ 3,000 - 4,000 rpm. My question is being the Boxster is water cooled, do you drive it the same way. I do take it up to redline just to keep the engine clean every so often. Appreciate your comments.
The car has an electronic rev limiter under acceleration to protect the engine. This rev limiter cannot protect the engine if you miss a down shift at high rpm.
