-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   OBD2 Code P0154 Question (http://forums.pelicanparts.com/boxster-cayman-forum/222448-obd2-code-p0154-question.html)
Imcoz 05-20-2005 02:43 PM
Anyone know which O2 sensor is Bank 2 sensor 1? - Trouble code says, Oxy Sensor Circuit No Activity (Bank 2 Sensor 1)
AFJuvat 05-22-2005 08:46 PM
Drivers side, before the catalyst.
It is easy to change, you will need a 22mm Wrench to remove it.
AFJuvat
Imcoz 05-23-2005 09:14 AM
Thanks AFJuvat.... not sure if you know... does that code usually get thrown if the sensor is expired... or could it just be dirty or something?
AFJuvat 05-23-2005 01:42 PM
Usually because the sensor is shot. You can put some good gas in the car and drive the car hard for a bit and see what happens, but usually, the sensor is long gone.
AFJuvat
Imcoz 05-23-2005 03:12 PM
Okay, Thanks again!
