odometer quit
The odometer/tripmeter quit on my 2000 S. The speedo still works. Is there a bulb in there for digital readouts? I know nothing about electronic gauges.
Thanks, Joe
Old 06-05-2005, 03:17 PM
Each of the 3 digital displays has a bulb on your year. You need to remove the instrument cluster to replace the bulb.
Old 06-05-2005, 04:42 PM
Thanks. Where do I search for instructions on how to remove the instrument cluster?
Old 06-05-2005, 09:26 PM
Remove the round dummy grill on the left and the #20 torx screw behind it. Remove the hazard switch button and the torx screw behind it. Lift the entire instrument cluster pod up and out of the dash. Put a towel under it while you change the bulb. You will see 3 tan bulb holders. The rest are black for the idiot lights.
http://www.renntech.org/forums/index.php?showtopic=3664&hl=bulb
Old 06-05-2005, 10:59 PM
