Supercharged Boxster
I recently purchased a 97 Boxster with a TPC supercharger kit installed. The car is not as impressive as I thought it would be, so Im thinking about increasing the boast a little. Any one have this kit? If so what boast levels are you running?
Old 06-18-2005, 09:13 PM
tholyoak's Avatar
If you want to blow up your engine feel free to increase the boost. The 4.5 psi is as much as you can safely use.
Todd
1989 911 Targa
Old 06-20-2005, 10:29 AM
that's pretty much what I thought. I saw your list of cars, I also have a 3.6 SC Im trying to sell. I wish the supercharged boxster was about as fast as my SC
Old 06-21-2005, 02:46 PM
tholyoak's Avatar
Cman,
My Boxster was a 2.5L supercharged with the TPC kit. Like you when comparing it to the 3.6L 911, it still was found to be lacking. Thus in went a 3.4L 996 engine and all is well.
Unless you lower the compression or figure out a way to add an intercooler you are pretty much limited to the 4.5lbs of boost.
Todd
1989 911 Targa
Old 06-21-2005, 03:03 PM
how hard is that conversion?
Old 06-21-2005, 05:12 PM
tholyoak's Avatar
Check out my post here:
http://www.renntech.org/forums/index.php?showtopic=4798
It will cost you about $10k minimum if you do all the work yourself.
Todd
1989 911 Targa
Old 06-21-2005, 05:36 PM
not including the motor, correct?
Old 06-21-2005, 07:04 PM
tholyoak's Avatar
That would include the motor if you find a good used one, a new (reman) motor from Porsche will cost on the order of $10k or so(rough estimate) since you wouldn't have a core so you would forfit the core deposit.
Todd
1989 911 Targa
Old 06-22-2005, 07:07 AM
Bez Bez is offline
Not sure this helps, but looked like a sweet deal so far...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33615&item=7981347810&rd=1&ssPageName=WDVW
'71 911E Targa rebuild project, '82 SC, '85 911 M491 cab, '90 C4, '85 911 cab, '77 911 C3 (all sold )
Old 06-22-2005, 07:19 AM
