Paul Stewart's Avatar
Blinking Coolant Light
My friends 99 Boxster's coolant light is blinking. When he first noticed it, his coolant was a little low. We added coolant, but the light still blinks. The coolant level(after driving more than 500 miles)is staying steady. The temp gauge always shows 180 after warmed up.
Any ideas?
1998 Boxster with M030 Sport Suspension, 3.6 liter/325 hp, Cayman S headers and mufflers, Console delete.
2001 Boxster bought new. Driven to the last 10 Parades! Autographed. No compression at 89,000.
Owned and repaired Porsches since 1974. Have driven them all the way the Dr intended...
Old 06-14-2005, 03:32 PM
Bez Bez is offline
I've heard of 2 issues regarding coolant system. One is the cap may not be sealing properly. Check trunk area for collant spray - teltale sign.
Also, the other is the coolant tank can crack and lose pressure (and coolant). Mechanic can do a pressure test to confirm.
I've heard both of these issues can happen to Boxsters and 996's.
'71 911E Targa rebuild project, '82 SC, '85 911 M491 cab, '90 C4, '85 911 cab, '77 911 C3 (all sold )
Old 06-16-2005, 06:56 AM
Imcoz's Avatar
Similar experience w/ my 99. Just when I thought I'd added enough to get the blinking light to cease, I added a bit more and it finally stopped. Not sure that helps.
Coz
88 911
72 914-6 Vintage Racer
76 914-6 Vintage Racer
Old 06-25-2005, 09:25 PM
expansion tank leak, buy a good used one. you have to remove the bottom plate that holds the chassis. 1 whole day needed to repair. tools-pliers,10mm socket, used expansion tank core.
I fixed my leak for under $50.00
Old 07-06-2005, 02:13 PM
