-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Boxster Error Code P134 (http://forums.pelicanparts.com/boxster-cayman-forum/248135-boxster-error-code-p134.html)
sgl944t 10-26-2005 09:17 PM
Can anyone help me determine how to resolve this problem. I initally had code that the dealer was a shut-off valve replacement and I replaced it. The next code was P1123 Oxygen Sensor (MAS) and I tried using Brake Clean but now I get P123 which is 02 Sensor Circuit No Activity Detected Bank 1 Sensor 1. I am thinking to get a new MAS Sensor and see if that solves the problem. Any ideas would be appriciated.
AFJuvat 10-28-2005 06:20 PM
You have a bad oxygen sensor, passenger side, before the catalyst.
NEVER use solvents around o2 sensors, it destroys them
AFJ
sgl944t 10-28-2005 09:11 PM
Error Code Resolved
I replaced the MAF Sensor and have 112 miles with no Engine Light. I had replaced the O2 Sensor already. Since I figured out from other posting information that the MAF was probably the main problem I tried the Brake Clean as a last ditch effort to not have to replace it, but I did.
