Question Boxster help required!!!
Five months ago I have a purchased 98' Boxster with a wee bit of a problem... Well I replaced the motor 2.5 liter three months ago to have the mechanic improperly install the tiptronic transmission causing that to break. I have just had it rebuilt which I have installed.
The problem now is I took it out for a test drive and went through the gears, I (pinned) floored it to have the car died at 5000rpm on acceleration. The engine turns over but won't start I have checked and the fuel pump is delivering at 55lbs. The only thing I have noticed is that the (tps) throttle position sensor is making a vibrating sound. Would the car run if this was defective?
I've spent more time and money trying to fix this car than driving it!!!!
Can anyone help?
Old 09-13-2008, 07:36 PM
Have you run the system check with either a PST2 or Piwis tester?
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-15-2008, 10:35 AM
Tags
sensor , throttle position sensor , tps , won't fire , won't start
