CV Boot replacement Q
Bently says I have to pull the track rod (with that "tie rod end" looking thingy on the end), and remove that long aluminum flat bar piece, which the pet calls a "strut".
I am worried about two things. 1) I dont want to chew up that tie rod end looking thingy by using my tie rod fork, and I dont have the special porsche tool to remove this. If the wheel carrier were steel, I would get out the BFH, and lay one good blow where the track rod attaches, But I am a bit afraid of that aluminum carrier. Any suggestion on how to remove # 17 from # 1 without damage. http://forums.pelicanparts.com/uploa...1231183310.jpg 2) If I remove this long aluminum strut, do I need to re-align the rear suspension. Unfortunaly I just had a four wheel alignment at the dealer, They aparently did not notice that the CV boot was bad. Must have done the alignment with their eyes closed. :mad: The strut is # 1 in the pic. http://forums.pelicanparts.com/uploa...1231183772.jpg |
Be sure and loosen the big wheel nut before lifting the car. I would have the rear alignment checked after doing this amount of work, IMHO. Hope this helps...:) |
Excellent !!!
Thanks. |
| All times are GMT -8. The time now is 08:32 AM. |
