-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   O2 Sensor / Cat Code (http://forums.pelicanparts.com/boxster-cayman-forum/487606-o2-sensor-cat-code.html)
RNajarian 07-25-2009 07:14 AM
Hello Gang
I was minding my own business driving on the freeway when the CEL light came on.
I immediately checked the code with my Durametric Scanner and got the following codes;
P0430 Porsche fault code 45 Cat conversion bank 2 exceeds limit value
P0159 Porsche fault code 23 Sensor ageing behind cat. conv cylinder 4-6
I suspect the problem is a bad O2 sensor behind the cat, bank 2
Anyone have a similar code?
Anyone fix it themselves?
How did you do it?
mikefocke 07-28-2009 12:51 PM
You swap with a new sensor
http://mike.focke.googlepages.com/oxygensensors
Just did it myself 10 days ago. I was lazy and had my local tire dealer install it for me. $37 labor (try that at a dealer). Ordered Bosch OEM part..see link for part #s.
Same day did my Honda...same OEM part but not Honda marked up price and $37. for the install.
Beware that area is hot so if you DIY it let it cool before reaching your hands in there.
