Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Is there a "common" power steering leak with 986's?
After having my '99 986 for a few months now I have had a blast fixing all the little "common" problems these cars seem to have... ABS light (fixed), spark plug tube leak (fixed), AOS lower boot torn (fixed) etc. This is a hobby car for me.
But now I've noticed that I needed to add power steering fuild to it. The PPI said there was a some PS fuild on one of the PS hoses running from the engine. Does anyone know if there is a common problem (seal vs. pump failure etc.) that I should suspect? I just haven't started taking things apart yet and thought I'd check with you guys first.
Thanks in advance for your input!
Joel
BTW - anyone thinking of having a PPI done... go to a Porsche expert... my guy wasn't and virtually everything said was incorrect or flat out wrong!
Old 11-08-2009, 09:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Sboxin's Avatar
There is a "weak link" in the PS return line red plastic clip that holds the return line into the back of the pump. The clip only holds the line - there are two rubber O-rings that seal the line to the pump.
Also, one of the hoses is an overflow and drops fluid right down onto the top of the engine - maybe this is the "source" of your PPI - and this would not be a real problem - maybe just check the fluid level on a regular basis (?) ...
You may other issues, but the red plastic clip was ours.
Take care,
Roy T
Old 11-14-2009, 03:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
