turboflyer's Avatar
Yet another Air oil separator Motorsport replacement?
Has any one done this for the 01S? I do not track the car so am not sure if the longevity of the much more expensive unit will do any better. I assume they both share the seemly fragile diaphragm. You would think there is a better unit some where.
Old 10-29-2009, 09:25 PM
turboflyer's Avatar
Well it is changed again. Unfortunately the diaphragm appears to be intact this time. It was a much easier replacement with the drive axel out for the differential oil change. So unless the seat was leaking or sticking it was not the culprit.
Old 11-08-2009, 06:10 PM
