Oxygen Sensor
Every 3-4 weeks for the past 4 months I've been pulling A CEL Code relating to either the O2 sensor or the Cat.
My car is a 2000 Base Model 986 with 140,000 miles. O2 sensors are the original ones put in 10 years ago in Germany. Logic tells me it is probably a bad O2 Sensor. I did hook the car up to my Durametric Scanner and read the voltages. The numbers were within spec at that time. I have noticed I pull the codes when it is cold outside (Southern California, 50 degrees is cold for us) I'm looking to change bank 2 first (both pre and post cat) then bank 1 ANY thoughts on which Sensor to buy? I'm leaning towards the Bosch OEM sensor sold by our host, however if any one has had any success with any other brand of O2 Sensor I would be glad to hear your opinion. Thanks |
I had a problem using the non-OEM sensors, I would go with the BOSCH ones. The heater element might be dead inside the O2 sensor, hence the readings only on cold days?
-Wayne |
I don't follow your logic
in changing one side and then the other. Usually the codes in this area are pretty specific as to the sensor they relate to. If in doubt, post the raw code here and someone with the ECU/DME manual will interpret them for you. The pre-cat (closest to the engine) sensors are usually the first to go. I would agree with Wayne, I've used the Bosch sensors with pigtails attached from the factory with much success. To me there was no risk of a wrong part and no risk I'd crimp the wires badly or not get the electrics watertight but I also didn't have to pay the car manufacturer's prices. Bosch is what Porsche buys, after all....and if they lasted 100k, you got about double what most people get out of them. They are worth replacing because, if the cats get fouled, you are in serious $$$ trouble and installation hassle. Part numbers and a how-to here. |
Good Suggestion Mike.
Here are the codes I've pulled since December 23, 2009. Dec 23, 2009 P1118 Porsche Fault Code 4 - Heating power O2S behind Cat c. bank 2 P0430 Porsche Fault Code 45- Cat conversion bank 2 Feb 6, 2010 P1118 Porsche Fault Code 4 - Heating power O2S behind Cat c. bank 2 P1117 Porsche Fault Code 14- Heating power O2S behind Cat c. bank 1 Feb 20, 2010 P0430 Porsche Fault Code 45- Cat conversion bank 2 P1265 Porsche Fault Code 301- Crash Signal The P1265 Code is unusual since it does not relate to the emissions system. Apparently it is an airbag code, signal implausible. I reset the codes, hopefully that one will not return. Based on these three cases I believe the post cat sensor (bank 2) is bad since it tripped the CEL on 12/23/09 and 2/6/10. In addition, the post cat sensor (bank 1) is probably bad since it tripped CEL on 2/6/10. The P0430 code indicates the catalytic conversion is too low. I am have read a few bottles of Techron will improve combustion and improve emissions. I am not sure how helpful this will be since I usually use Chevron gas anyway. What do you guys think? Both POST CAT Sensors definitely. Should I do the PRE CAT sensors? And finally, I hope this isn't a silly question, what does Starter Cat Mean? Is the Post Starter Cat O2 sensor the closest to the rear bumper/muffler? Thanks |
Here's a blurb from my new book on using non-OEM 02 Sensors:
-Wayne |
Thanks to everyone for your input. The write up on the O2 sensors from your book was great Wayne. Can't wait to pick one up.
Looks like I'm going to be ordering two post cat sensors tonight. And I think they qualify for free shipping. :) |
-Wayne |
I'd suggest there are more options than the ones Wayne has listed if you divide them this way:
1. Walker generic sensors without any wiring (often seen on eBay). 2. Bosch sensors without any wiring 3. Bosch sensors with Porsche model specific wiring and connectors 4. Porsche branded sensors with Porsche model specific wiring and connectors With the Walker brand, there are people who have made them work and people who absolutely say they don't work as they give out a different profile signal than the ones Porsche tunes its ECU to. With the Bosch brand without wiring, you become responsible for the crimping (the factory does it on an expensive automated tool and then tests the results) and weather-tight sealing. Plus you are reusing wires that may themselves be part of the problem. The Bosch sensors with wiring and connectors are exactly the same ones Porsche uses, spray paints on a Porsche part number and repackages in Porsche branded packaging. They often cost less than half what the Porsche branded ones cost. I've used 2 of these in the pre-cats of my '01S and both worked just fine. They come in 2 different part numbers because they have different lengths of wiring (same sensor) for use in the pre or post cat sensor positions. Get the right one. |
Right, I agree with Mike, I like choice #3 - the BOSCH OEM ones. Sorry if that wasn't clear from my previous posts...
-Wayne |
Thanks Guys. I'm looking at the Bosch sensors with the connectors right now. Fed Ex just delivered them. I plan on installing them this weekend.
Thanks again for your insight. |
| All times are GMT -8. The time now is 07:48 PM. |
