-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   need part number ! (http://forums.pelicanparts.com/boxster-cayman-forum/536817-need-part-number.html)
911ballin 04-14-2010 02:39 PM
need part number !
hi need to get part numer of the plastic black pin that hold the carpet panel inside rear trunk of boxster
FANBOY 04-15-2010 11:14 AM
There are a couple, 999-703-432-40 and 999-507-529-40
911ballin 04-15-2010 04:43 PM
whaere can i see the parts numbers???
Because i also need the part number of the hookof the door lock the one in body frame ! where driver door engage when you close the door! is like cirlcle hook with metal plate and 2 screws maybe have a seal also! i need all parts number my driiver door is little out line want to make it perfect i guess better will be buy parts new ! evenm the screws 1 seems like the problem will be bed hook? i noted the frame has tiny little marks taht line with little marks in the plate ! taht soemone know how it works to line door!
911ballin 04-20-2010 10:42 PM
i have been worry because my door is out line driver side !so i like post the passanger door that is perfect and pic of driver door here is out line! also put picture of the hinge taht aperenty in my car the metal develope little crakc maybe that is cause the out of lline! bodyshop recommend welded in back !!but maybe is hard to access there? thats soemoen can describe how or what is behine there !!i image porsche develop a more strong area there that hold the door hood what is behind the panel? i will like to buy the 2 new screw and the metal plate with hood and see if bodyshop can realine it and fix this ecause i don't have clue how to adjust this part!http://forums.pelicanparts.com/uploa...1271828217.jpg
this is passanger and perfect see line a little more inside that boidy line http://forums.pelicanparts.com/uploa...1271828291.jpg
this is driver door where is little out linehttp://forums.pelicanparts.com/uploa...1271828342.jpg
http://forums.pelicanparts.com/uploa...1271828374.jpg
http://forums.pelicanparts.com/uploa...1271828402.jpg
http://forums.pelicanparts.com/uploa...1271828429.jpg
ok last pics there is the crkas tiny ones NOT SURE IS IS JUST PAINT o or in fact the sheet metal crack! bodyshop thinks is metal crack and plan reweld the behine part a piece metal to strenght it and repait and adjust is this coomon? thanks
911ballin 04-26-2010 04:23 PM
any help or explanation what is causing door out line? also parts numbers please if someone knows?
Wayne 962 04-26-2010 10:24 PM
I suggest that you get the proper triple-square tool and remove the door catch and take a closer look. Looks like paint to me, I don't think this is causing your problem. You may have wear in your latch mechanism in your door. I think the shop is guessing and I think they are on the wrong track.
Remove that piece and then post pics of what you find...
-Wayne
JMatta 04-27-2010 05:23 AM
Are you certain the driver's side of the car wasn't hit in an accident at some point? When you have a gap like and tell tale cracks, there must have been an "event" at some point in the car's life.
911ballin 04-27-2010 08:48 AM
where yo get that tool ???? part number?? also seems like that catch have seal is coming off in one side i will like order new screws new seal ,, jut to be readey when i take it off parts numbers?
Jamikest 04-27-2010 05:28 PM
Triple squares are common sockets, like any other socket. Go to your local tool supplier.
Here in the states- Sears, Snap-On, Cornwell, Matco etc. I don't know suppliers in Europe.
EDIT: Hazet. Hazet makes triple square tools, and is a European company
911ballin 04-27-2010 07:59 PM
OK ,, one thing maybe be associated with that door out lin not sure since i got car i noted that the secure little light in door wasn't going off after door close , was on for long time !! even i just park the car close door without locking the car came back and car driver light door was one 20 30 minuets after was JUST WHEN I LOCK THE CAR WITH THE REMOTE KEY THAT SOME SECONDS LATER IT WAS OFF !! SO I DON'T KNOW HOW That light is connected to latch lock ? will the Little out line causing this add behavior of door light????
by the way parts number???? any one have diagram how is this catch hook or what is behind that door frame ,, what hold the screws behind thanks !! i'm affraid if i take off the catch how it supposed to line it back in right way i don't want to do any more gap to the door or screw it bad!
911ballin 05-07-2010 02:13 PM
STILL NEED THE PARTS NUMBER FOR THE DOOR CATCH AND SCREWS ! also seems is little seal between metal hook catch and body of car please help !!!
Wayne 962 05-07-2010 03:19 PM
I wouldn't worry about taking off the door catch, you can't make it worse. Yes, your door lamp is probably related to this issue - the switch is located inside the door latch mechanism. Here are some articles to assist you removing the door panel and then getting to the door lock:
Pelican Technical Article: Door Panel Removal / Mirror Switch Replacement - 986 Boxster (1997-04) - 987 Boxster (2005-08)
Pelican Technical Article: Door Lock Mechanism / Door Handle - 986 Boxster (1997-04) - 987 Boxster (2005-08)
For a 2000 Boxster, the screws are N 907 985 02 and the catch itself is 3B0 837 033 P. Just cut and paste these into our search engine to get pricing and to order.
We have triple-square tool sets in our catalog, although I'm not sure what size that is:
http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT055_pg11.htm
-Wayne
911ballin 05-07-2010 07:04 PM
ok wayne thanks ! i will order new screws, but waht will be the best way to aproach this matter ? un screw the top or lower bolt how you get correct you can see from my pics problems is basic the top part of the door out line for few mm, i can see door plate cathc has this tiny lines probably for get line how they read?or work?
then knowing my door light only goes off when car is lock with key like alram armend!! waht is causing this wear lock or door lock is not reaching totally close point and there is sensor inside? that sense metal to meatla thing how it works? thanks
Wayne 962 05-08-2010 12:19 AM
1- unscrew the door latch mechanism.
2- take photos
3- post them here
4- wait for further instructions.
-Wayne
