is my car making right noises?
as a newie owner not sure is car making right noise ,, reading some people with bad oil separetors make noise , my car as lttle noise when when is cool not sure if is bad aos , ut my car dosen't smoke here video of today i start it after almos 14 days of been park! wondering if noise is belt, or tranny getting warm , for sure car needs clutch job soon! maybe is cltch bearing! YouTube - noise like belt or bearing from tranny in porsche boxster s 02 here is second video
YouTube - porsche s wondering about noise brom belt? |
sorry second video is this
YouTube - noise like belt or bearing from tranny in porsche boxster s 02 |
The video's audio is too muddled to make out if thats a ticking or squeaking or what?
From the video it almost sounded like a vehicle with a lifter ticking.. But your description of the sound doesn't describe that at all. If the car was stored for a while and a lifter bled down- running it for a while should pump the lifter back up. But again- I don't trust the audio 100% |
Author of "101 Projects"
Can't tell anything from the video, but you shouldn't run the car with the cover on it.
Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
You can try running it without the belt for a very short period of time (30 seconds) and see if the noise is still there?
Wayne
I would remove the engine cover behind the seat and listen to the idler bearings and tensioner. Also, check your power steering fluid. Then disconnect the serpentine belt, crank the car and listen again. If it goes away, it could anything that the belt drives. Happy huntin.
-Wayne
