no throttle
had a frost plug give in the cylinder head due to high heat. pulled motor, pulled heads, reseated frost plug. set cams, i think the right way, they look good even after i pulled the motor out for the fourth time. motor will start but rough idle and eventually run out of fuel. pedal does nothing.
Old 08-27-2022, 01:18 PM
it's a 2.5 l out of a 99 boxter have good fuel pressure will do compression check next
Old 08-27-2022, 03:53 PM
well 50 pounds of fuel and good compression all the way around. guess i timed the cams right
Old 08-28-2022, 01:34 PM
Dme 5.2.2
not getting good continuity to ground out of the dme for the sensors or going out to the relays. i have good grounds, brown wire, from the connector to the ground points. Am i missing something that is not switching, or is my DME shot?
Old 09-25-2022, 12:14 PM
