is my car making right noises?
as a newie owner not sure is car making right noise ,, reading some people with bad oil separetors make noise , my car as lttle noise when when is cool not sure if is bad aos , ut my car dosen't smoke here video of today i start it after almos 14 days of been park! wondering if noise is belt, or tranny getting warm , for sure car needs clutch job soon! maybe is cltch bearing! YouTube - noise like belt or bearing from tranny in porsche boxster s 02 here is second video
YouTube - porsche s wondering about noise brom belt?
Old 04-20-2010, 11:04 PM
sorry second video is this
Old 04-20-2010, 11:14 PM
Jamikest's Avatar
The video's audio is too muddled to make out if thats a ticking or squeaking or what?
From the video it almost sounded like a vehicle with a lifter ticking.. But your description of the sound doesn't describe that at all. If the car was stored for a while and a lifter bled down- running it for a while should pump the lifter back up.
But again- I don't trust the audio 100%
Old 04-22-2010, 05:34 AM
I would remove the engine cover behind the seat and listen to the idler bearings and tensioner. Also, check your power steering fluid. Then disconnect the serpentine belt, crank the car and listen again. If it goes away, it could anything that the belt drives. Happy huntin.
Old 04-22-2010, 06:02 PM
Author of "101 Projects"
Wayne 962's Avatar
That's good advice, maybe take a video sound of the engine without the cover on. Do you have instructions on that? I'm in the process of uploading preliminary tech articles, I could send you a link if you need it...
-Wayne
Old 04-22-2010, 10:33 PM
