-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   check engine light (http://forums.pelicanparts.com/boxster-cayman-forum/548548-check-engine-light.html)
dongenaro 06-17-2010 12:52 PM
check engine light
whenever i stop for refuel, motor will turnover but not crank unless gas pedal is depressed, interestingly i refueled cold at home from a gas can and it works correctly but the fuel gauge registers the previous half tank level. at a subsequent refuel at the gas station same starting issue but gauge works. check engine codes for O2 sensor rich/lean.had it checked out at garage & was told MAF sensor,but this does not make sense as the car runs great otherwise. i'm thinking maybe evap system? anyone had a similar issue or ideas?p.s. i cleaned MAF,installed new plugs & filters, no difference
KevinH1990 06-17-2010 04:00 PM
Check this thread: Boxster hard to start after filling with gas - RennTech.org Forums
Wayne 962 06-18-2010 02:34 AM
Changing the charcoal canister typically fixes this problem. It's this part here:
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
-Wayne
