Advise on IMS install
Hi everyone. It's about time for a new clutch on my 2000 2.7L so I'm going to put the LN bearing in as well as a new RMS. I've been pouring over all the online instructions and tutorials and have a question about locking the IMS. I'm seeing two different methods and wonder which is going to be the best. One method involves locking the crankshaft at TDC with the 5/16" rod, popping two of the green cam plugs and then using the $200 Porsche cam locking tool to hold everything in place. The other method presented here by Wayne has you mark the cam timing after positioning the IMS sprocket so you can use three studs to bear up against it and hold it in place. Apart from saving the $200 for the Porsche tool I'm wondering what the pros and cons are of each method. Thanks for any insight.
Old 06-10-2010, 11:36 AM
When I did mine I did not touch the cam plugs nor lock the cams. Jake Raby told me to lock the motor at TDC, pull the front two chain tensioners, R & R the IMS bearing, replace chain tensioners, unlock the motor, you're done. My write-up:
IMS, RMS, Tranny R & R Tips - RennTech.org Forums
Old 06-10-2010, 12:52 PM
That's an excellent write-up. Thanks for sharing that.
Old 06-10-2010, 03:17 PM
No problem. If you want any advice on what worked out for me shoot me a PM or email, that's what these forums are for.
Old 06-10-2010, 04:24 PM
Author of "101 Projects"
Wayne 962's Avatar
Just for reference, BerneseMtnDog is referring to my procedure here:
http://www.pelicanparts.com/techarticles/Boxster_Tech/14-ENGINE-Intermediate_Shaft_Bearing/14-ENGINE-Intermediate_Shaft_Bearing.htm
Putting in the set screws is really the best way to go because your pinning the intermediate shaft in place. You'll see when you pull the bearing - if you don't do this, it will wobble all over the place. On the 5-chain motors, it's pretty difficult to mess up the timing, but you should check it afterwards anyways, just to make sure (it's not worth the potential $15K engine replacement costs, to save $16 in camshaft end plugs).
Hope this helps,
-Wayne
Old 06-10-2010, 11:43 PM
Wayne, your knowledge and experience completely overwhelm mine, checking the cam plugs and timing would be done if I had read your article before doing mine. In going to Jake I thought I was already "ascending the mountain" lol. Cheers
Feel free to use my photo in any of your write-ups (note the size, ft. lbs. torque value along with torque order written):
Old 06-11-2010, 04:04 PM
Thanks again for everyone's input. Makes this job seem not quite as forbidding as it before. I should have the tranny out this weekend and will be able to identify what IMS bearing I have and order up some parts.
Old 06-11-2010, 06:41 PM
What's the general wisdom with regard to replacing rather than reusing some of the nuts and bolts removed during the process? I'm thinking I will replace all the axle bolts ( I buggered up a couple of the Allen heads) but I'm looking at the tranny mount hardware and wondering if replacing those wouldn't be a good idea as well??? Any others to consider? Should fresh green Loctite also be applied to all these green threads? I'm assuming that's green Loctite anyway. Thanks in advance.
Old 06-11-2010, 08:46 PM
When I did mine; New Flywheel bolts, new pressure plate bolts, new axle bolts. Blue Loctite was used on them, Red Loctite on the IMS cover bolts, Green "wicking" Loctite used on the IMS bolt / nut.
Old 06-12-2010, 04:33 AM
Just wanted to post an update. Over the weekend I finished up and got the car back on the road. I replaced the clutch and flywheel and various tranny bits (the old clutch was a little "grabby") New clutch engages much better and smoother over a little longer pedal travel. Big improvement.
I pulled and replaced the IMS bearing with the LN retrofit. Mine was a dual row and was a PITA to pull out. Original bearing was in good shape but the LN bearing is clearly superior when comparing the two. Even with the IMS sprocket held by the 3 set pins I ended up bumping it out of position when putting the new bearing in. Of course it stressed me out to no end but after getting the new one in and the tensioners back on I could see my cam marks we right on and by rotating the engine I could see all was good. (A note to Wayne: in the IMS tech page the right and left tensioner pictures and descriptions are are reversed).
My rear main seal was only slightly seeping and was also replaced. I was able to rent the official Porsche tool to install the new seal.
While I was in there I replaced the air/oil seperator mainly because it was very easy to get to with the tranny out.
Only problem I saw was an oily wet oil filler tube which I also replaced.
Finally a new serpentine belt and I was done. Car is a 2000 2.7L with 86k on it. There are some other things I'd like to do but I need to rest and get motivated again. This was the longest repair I've done to a car and the first clutch I've done. Thanks to everyone who has shared their info and advice. I couldn't have done this without the Web and folks willing to share. Kudos!!
Old 06-28-2010, 11:28 AM
Thanks! One other thing I forgot to mention. The new LN bearing didn't use any spacers. The new IMS cover has this extra amount machined into it. Just installed the bearing, then the retaining spiroloc, and then the cover. Thanks again for having such great tutorials.
Old 06-29-2010, 08:12 AM
Wayne 962's Avatar
Right, the LN kit has a custom-made end cover for the shaft bearing that fits the single-row bearing into the double-row area without the use of spacers. The Pelican kit uses the stock housing and spacers.
thx,
Wayne
Old 06-29-2010, 12:10 PM
