Very true, but as my clutch is working strong, I am a ways from that point as well. :)
We work from an appointment only basis. Our primary work is M96 engine development and engine production, service and IMSR procedures are done when we have openings. The fall and winter are our crazy times of year and they fill up fast. |
Some other things to think about - the 3rd radiator. If you install the 3rd radiator, then the cooling effects won't be fully utilized until the thermostat opens up completely. The stock t-stat with the 3rd radiator will act to artificially inflate the operating temp of the engine because the t-stat will close back up when the coolant is cooled down below the opening point. Also important to consider are the cooling fans. Although the low-temp thermostat opens at 160 or so, the fans won't kick on until the temps get much higher. You can trick the car into putting the fans on earlier, but in most cases that is not necessary. -Wayne |
-Wayne |
My experience
Well, after all that great feedback from everyone on the boards, I decided to try the low temp thermostat. My experience thus far is that the temperature gauge simply doesn't peak past the zero in the 180 mark and come back down as it did before. It reaches operating temperature and maintains.
While moving the gauge will reach the 180 tick mark and remain steady. While in traffic it is a little higher between the zero and eight. Other than that I've noticed no difference from my layman's point of view. Thank you everyone who chimed in with the advice. I feel very safe with the advice on this forum! |
Since the temps of the engine are lower, you want to make sure you increase your oil change frequency. I recommend no greater than 5,000 miles.
-Wayne |
Oil and thickness
From what I have read, most oils are thicker when cold an thin out as temp goes up. Thats why in colder climates you use a thinner oil, if not good luck on trying to start your car. If your not tracking your car theres no need for a lower temp thermostat.
Just my thoughts. Randy |
Randy |
When I replaced the 90k mile water pump I also installed the 160 deg t-stat along with the Boxster S type oil cooler. All 3 of these items combined have worked very well for me. When we are crusing the temp gauge rarely goes over the white 'tic' before the 180 mark and when in traffic in the summer months the needle is right at 12:00 high and goes back down as soon as the car is back in flowing air. The center rad is on my possible upgrade list but the car has 95k miles and seems to be running fine so I'm inclined to leave it as is.
Iii
Probably one of the most misunderstood factors about multi-weight oil is do they actually appear thinner when cold then when hot. The short answer (unfortunately) is both yes and no as the result of the convoluted way tech types look at oil.
Straight 5 weight oil will have viscosity values at both low (say 40 degrees C) and high temps (say 100 degrees C). The hot temp viscosity will be lower than the cold temp by a considerable value, depending upon the measurement method applied. Same test on straight 30 weight oil will produce values that are higher at either temperature, a function of the polymer chemistry in the oil molecules. Nothing unexpected here. Enter VI (viscosity index improvers). When added to the 5 weight oil, you still get the same low temperature viscosity, but when heated, you get the viscosity of the 30 weight oil at that temperature. Cold, the VI package allows the oil to drop to its base or “winter” weight (10 in a 10W-40 oil). As the oil begins to warm, the VI package modifies linkages across the polymer chains, which gives you the higher “hot” apparent viscosities of a heavier weight oil (until the VI package begins to degrade). Technically, it can be argued that “viscosity index” improvements are actually “reductions” in fluid thinning under increasing heat, but to the engine it is the apparent cold viscosity of thinner oil, but the viscosity of higher weight oil when hot. In absolute terms, viscosity does go down with increasing temperatures; but the engine sees an apparent increase in viscosity (or oil weight) when compared to the colder starting temperature. All a mater of perspective…………… |
Question for JFP
I have a 97 986 133k on it, live in southern Cali, what oil would you use? Btw I dont track the car, but is driven daily and does see traffic.
I would stay with a 10W-40 such as Castrol Syntec (ACEA A3, B3, B4 rated) and plan on changing it in the 5-7K (max) mile range. As an adjunct, I would also suggest both the 160 degree stat and the "S" oil cooler, both of which will help to protect both the oil and the engine long term. While other may feel differently, we have been running 160 stats in several cars for a couple of years now, some of which see heavy use, others are garage queens. UoA’s on all of them say the oil is lasting longer, and there are absolutely no signs of increased water or fuel contamination; and no signs of any sludge build ups.
With the 160 stat, the engine is running around the high 170’s to low 180’s (compared to often well over 210 with the OEM stat), more than hot enough to burn off contaminants; the oil is also seeing lower temps as well (limited experience with two cars with oil temp capabilities say 20-25 degrees) which appears to help the oil “stay in grade” longer between changes. Not a bad thing……. |
I appreciate JFP's knowledgable contributions to these forums, and am taking his advice on cooling system improvements, as I have followed his oil recommendations. All proven by in-service testing and UOAs.
I have my low-temp thermostat and "S" oil cooler on the way, along with a new water pump. Looking forward to putting them in in the next couple of weeks, and getting my extra 5 HP too! |
| All times are GMT -8. The time now is 12:08 AM. |
