-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Help! I'm having some trouble installing my new exhaust (http://forums.pelicanparts.com/boxster-cayman-forum/555040-help-im-having-some-trouble-installing-my-new-exhaust.html)
BoxsterDan 07-24-2010 06:12 PM
Hey everyone,
I haven't posted here before, but I've been a long time reader.
I'm in the process of installing a GHL exhaust to my 2000 2.7 Boxster. However, I have run into some difficulties. 2 of the bolts that hold the "U" pipe to the cats broke, one on each side and I am having no luck whatsoever removing the nuts (one on each side) from the "U" pipe joint that connects to the OE exhaust itself.
I went to the auto store down the street and got some new bolts, they're not metric, but I'll use them, with new nuts (4 bolts total).
BUT I still can't get those darn nuts off the joiner at the exhaust.
I need the car tomorrow and I have the whole back taken down (bumper etc).
What should I do???
I've tried hitting it with PB blaster and tapping it with a hammer, but the stubborn things one move.
Any tips? Should I run the car to give them some heat? Is there risk with some of the exhaust taken down already? CEL, damage, Fire?!?
I really appreciate anyones help at this point... kinda desperate. :confused:
Thanks,
BoxsterDan
orcadigital 07-24-2010 11:00 PM
I'd recommend heat through use of a blow torch. I am unsure about running the engine to generate the heat, but I would think that would be a last resort. Otherwise you are trying to get in there with a nut-buster, dremel, or drill.
BoxsterDan 07-25-2010 12:23 AM
Thanks for the tip
Do you think Porsche still sells the joiners for the "U" pipe? Ideally, I'd like to replace all the hardware that's rusted: The 4 bolts between the car and "U", the 2 between the "U" and exhaust, and the 4 that hold the hanger loops (they seem to be affixed to a ~1"x2" plate, 2 bolts to each plate).
Where could I find those parts? I hate to use generic Home Depot hardware, and I also don't know where I'd get the joiner sleeves (or whatever they're called).
Thanks!
