Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
Alphaboy1's Avatar
Compartment Lid on Door
Hi
My little hinged door that lifts up on inside door panel on my 2002 Boxster S needs a little touchup. Would you recommend Black Leather Dye touchup or a Black Plastic Autmotive paint? It is not too bad so light coat of something is what is needed. Not sure what that something should be?
Regards
Paul
Old 09-03-2010, 02:06 AM
I would use a plastic paint. It has excellent adhesion qualities, and shouldn't rub off like a dye might. Just make sure you get a similar finish (flat, matte, gloss, I don't actually remember what mine are). Ideally you will want to clean it with a prep cleaner of some type, just to get any oils and debris off as with any painting procedure.
1997 Boxster 2.5L
1975 911S Project
Old 09-03-2010, 05:39 AM
My other ride is a C-130J
RNajarian's Avatar
Originally Posted by Wayne at Pelican Parts View Post
Can you post a photo?
-Wayne
I had the same problem as Alphaboy1 but was able to find a pair of clean lids for the compartment from a member here on Pelican.
HOWEVER, the act of resting my arm on the pocket lid (in the door) which dulled the finish on the plastic on the pocket lid also dulled the finish on the upper portion of the door pocket.
I've posted these photos which I hope show the dulling of the finish. Not a big deal but I would like to clean this up. You can actually see where the portion of the plastic lid which is covered by the pocket lid and the portion exposed to rubbing of my elbow.
1975 911 Targa S 3.0
2005 Cayenne Titanium Metallic
2010 Mercedes-Benz E350 2012 Mercedes-Benz C350
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-05-2010, 07:37 AM
On my '04 the finish on the lid appears to be wearing/chipping off. Sanding and painting might work but I'm not anxious to try it.
As to the worn look on the top of the pocket, you might try Meguires plastic cleaner or polish. Wouldn't hurt anything and might bring it back.
Old 09-06-2010, 07:07 AM
Author of "101 Projects"
Wayne 962's Avatar
I thought that maybe a new one would be reasonably priced from Porsche - my mistake. The lid is about $550. Porsche needs to get their act together with respect to replacement parts for these cars, this ridiculous stuff is going to hurt the image of these cars in the long run. This must be an oversight or something, the earlier ones are like $75, which is what I would probably expect them to cost.
I would be wary of putting any ink or dye on a part that I put my elbow / shirt on. If not done 100% properly correct, then you can have the dye possibly come off onto your clothes.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997
Coming Soon:
SPEED READ: Porsche 911 (October 2018)
Old 09-06-2010, 10:57 AM
JMatta's Avatar
I covered mine in leather...simple project, looks 100% better. Paint will only scratch again and probably won't match.. Mine were in perfect condition, but I still wanted upgrade the covers.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 09-07-2010, 05:39 AM
RNajarian's Avatar
Ohhh JMatta NICE job. I did the same with the center compartment lid (between the seats) That was a pretty simple job. I'm going to give your upgrade a try.
Wayne,
Below are photos of my old driver pocket lid, illustrating the wear on the edge.
Old 09-07-2010, 05:52 PM
Alphaboy1's Avatar
Wayne,
Thats exactly what mine look like! So pretty common.
Regards
Paul
Old 09-08-2010, 02:40 AM
JMatta's Avatar
I read the idea to cover the doors with leather from another poster on a different forum; it is certainly not my unique idea. I'll see if I can find the original link or at least explain what I did.
2002 Boxster S
Old 09-09-2010, 06:37 PM
Alphaboy1's Avatar
Please do... I would guess you used some sort of Cement to adhere the leather?
Regards
Paul
Old 09-10-2010, 12:47 PM
Aron in Toronto's Avatar
Pedro has a DIY write up on his site.
Leather Upholstering
Aron
1997 Boxster
Old 09-11-2010, 05:34 AM
