-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Alignment question (http://forums.pelicanparts.com/boxster-cayman-forum/565814-alignment-question.html)
BerneseMtnDog 09-22-2010 10:07 AM
Alignment question
Hi all. I'm about due for a new set of shocks and was considering the "ROW M030" kit with springs, shocks, and sway bars. I'm wondering what this means for the alignment shop I go to. Since the kit slightly lowers the car will it have new alignment values or will the original factory ones still hold true? I suspect it will need to be aligned to different values. I don't want to put these on the car if my alignment shop won't know what to do with it. Thanks in advance for any advice.
s_wilwerding 09-22-2010 10:42 AM
You can still align it at factory specs with the ROW M030 - the advantage with the kit is that you COULD increase camber if you wanted, past what is possible with the stock suspension.
