max rear camber with PSS9
Hi,
i got hold of some reasonable priced used PSS9 and was wondering if someone who has PSS9 could tell me what the max neg REAR camber is I can get w/o additional camber plates or GT3 control arms. BTW: I have rear adjustable toe links
I was hoping for -2.5 degree
For the front I have GT3 lower control arms, so I am all set there
This is for a 2002 986S
2009 Carrera 4S, PDK
1990 964 Targa
2018 Range Rover Velar
Old 02-24-2011, 04:14 PM
Author of "101 Projects"
Wayne 962's Avatar
Interesting question. The PSS9 system doesn't have adjustability for camber. The system is adjustable for height and for spring damper. However, when you lower the car, your camber will change, and you will have increased negative camber. This is because the suspension geometry along the upper arm increases in angle, while the lower arm largely stays the same, resulting in the top of the wheel slightly pulling inwards.
When we installed the PSS9 kit on my Boxster, we introduced a *lot* of negative camber because I lowered the car way down. I don't have exact measurements, but it was immediately visibly noticeable.
-Wayne
Old 02-24-2011, 05:34 PM
Thanks Wayne
1990 964 Targa
Old 02-25-2011, 09:10 AM
On our Spec Boxster racecar with PSS9 shocks we were able to get 2.9 degrees in the rear. The bottom of the fender is maybe .5" above top of tire (255/40/17). Should be able to get 2.5 degrees easy. We do have the adjustable toe links to get the toe out.
Old 02-25-2011, 09:18 AM
yep, -2.5 degrees was easy (with adjustable toe arms)
1990 964 Targa
Old 03-10-2011, 09:04 PM
