What is the name of the tool?
Hi all,
I am trying to remove the Boxster doors in my SPB race car.
I saw a special bolt at the inner door. Wondering what I need to loosen it so I can take the door panel off from the car.
Is 12 points spline bit socket set what I need?
Thanks.
Old 01-06-2011, 02:39 PM
JFP in PA's Avatar
XZN (also called triple square) SnapOn and others carry them...........
Accrochez-vous bien de vos rêves..........."
Old 01-06-2011, 03:40 PM
Than you, guys
Old 01-07-2011, 08:52 AM
JFP in PA's Avatar
Wayne, you should look into carrying the “stubby” metric XZN, much more practical than the long shaft style. The 10MM stubby (the one use to remove the XZN fastener on the bell housing) is barely an inch in length, allowing you to get at the one problem bolt……………
Old 01-07-2011, 01:18 PM
Author of "101 Projects"
Wayne 962's Avatar
Yup, gosh, it was about seven years ago when we first put up our tool section - it's time for a serious overhaul. There's a lot of new stuff that we need to add.
-Wayne
Old 01-08-2011, 12:46 PM
