-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   replace spark plugs without jack stands.. (http://forums.pelicanparts.com/boxster-cayman-forum/591138-replace-spark-plugs-without-jack-stands.html)
kx9862002 02-11-2011 02:36 PM
want to change spark plugs but can't persuade myself to use jack stands...lol
any has done replacement of spark plugs without jack stands?
will ramps be ok for this project?
Zeke 02-11-2011 05:24 PM
You'd need at least ramps and sure, they're OK if you can get the car up om them. Some people use a jack to raise the car and slip the ramps under the tires. You have to raise the car pretty high because of suspension droop.
Others may tell you the having the rear wheels off the car provides more light and room to work.
Boxsters are pretty low, but the position of the rear wheels probably allows backing up ramps. You sure wouldn't be able to drive the front up ramps AFAIK.
kx9862002 02-11-2011 08:41 PM
I am gonna try to do that on ramps...
thx for the reply.
WhipE350 02-11-2011 09:18 PM
I just jacked the car up on one side, took the wheel off reached in and did them...first side was slow cause I always take my time while learning. Put the wheel back on went to the other side and flew through the second 3 in 20 minutes. Jack stands never came out, just a block under the frame that the wishbone connects to near the cam bolt for safety.
Wayne 962 02-12-2011 12:48 AM
Jack stands are your friend, you shouldn't be afraid to use them. Complete article on them here: Pelican Technical Article: Jacking Up and Lifting the Boxster on Jack Stands - 986 / 987
-Wayne
kx9862002 02-12-2011 09:52 AM
-Wayne
I have read almost all of them, but the only one I tended not to read is this one.
I also have this book, I read it over and over again, but never read the jacking one. :D
I guess it's called phobia in phychology.lol
Wayne 962 02-12-2011 12:49 PM
If you're nervous about jack stands, these are what I use. Not cheap, but effective, very stable and *not* made in China:
Pelican Parts.com - ESCO Flat Top Jack Stands
http://www.pelicanparts.com/catalog/...lder/10498.jpg
-Wayne
BYprodriver 02-12-2011 05:11 PM
+1 on these jackstands, I use these to get the car up high enough to remove engine &/or transmission. If your floor is painted these don't crack the epoxy Too.
Wayne 962 02-12-2011 07:04 PM
They are indeed very good on many counts. I don't like jack stands that cost $20 and are made in China. Seems to be those are almost all you can buy these days (except these ones of course).
-Wayne
Zeke 02-13-2011 08:39 AM
They look nice and I like the design. I wonder if they are made locally because I bet I could get a job there welding. I know I can weld better than the weld on the RH leg base.
Wayne 962 02-13-2011 11:10 AM
I'm not sure where they are made, but I just sent an email to AC Hydraulic asking if they manufacture this style as well. I'd rather buy them from Denmark and have them shipped with the jacks we import, than buy these piecemeal from the middle of the country.
-Wayne
kx9862002 02-13-2011 12:07 PM
this looks well made.
Wayne 962 02-13-2011 12:23 PM
Here they are holding up the 959!
-Wayne
http://forums.pelicanparts.com/uploa...1297628607.jpg
Zeke 02-13-2011 03:51 PM
Well, I have to admit I was being a bit snarky. The pic of the other style in the Pelican catalog makes the stand look a lot better.
http://www.pelicanparts.com/catalog/...r/P1016543.jpg
cowfly911 02-15-2011 08:44 AM
-Wayne
Just ordered a set! Thanks for the heads up Wayne.
Wayne 962 02-15-2011 01:02 PM
I saw that come through! It made me think that I should probably order another set for me too, as I only have one set here right now.
-Wayne
cowfly911 02-15-2011 03:29 PM
Don't take mine! ;)
Looks like I am going to need them in a bad way....
Wayne 962 02-15-2011 06:02 PM
Originally Posted by cowfly911 (Post 5848776)
Don't take mine! ;)
They are already in the mail on their way to you!
-Wayne
Zeke 02-16-2011 01:22 PM
So, is there a jack-top adapter like the thing you can get for the typical floor jack that makes the jack flat on top?
I have 8 stands and am having a hard time thinking I have room for 10 or 12. ;)
Wayne 962 02-17-2011 02:28 AM
Not that I'm aware of. Sounds like a good opportunity for a product to be made!
-Wayne
mcmike27 02-17-2011 11:30 AM
I use hockey pucks...with a little dremel magic they fit perfectly on my jack stands and I used another puck and cut out the 'oval' shaped opening where the jack stand sits and used a drywall screw and attached it to my customized pick and they fit exctly and provide a rubber cushion between the frame lift point and jack stand. I also cut a slot in one puck so I could jack our 98 986 with the unibody weld running along side the frame so it wouldnt get crushed when I use that to lift the car for easy quick lifts. I then can slide the jackstand in and have 1 whole side of the car up and on stands with one lift they work great. If you'd like I can take digital pics so you can see how I modified them. Just let me know and I will paste them.
Wayne 962 02-17-2011 12:38 PM
Sure, pics would be great!
-Wayne
Zeke 02-18-2011 08:16 AM
Ditto.
