youngone's Avatar
Tires- How old is too old?
I am looking for a consensus on aged tires. Three month owner of a 2003 Boxter S with 10 K miles. Original Pirellis. My experience with tires was to be cautious of over 5 years as the rubber can harden, etc.. Any shared thoughts?
Old 02-14-2011, 02:32 PM
2003 with 10K miles? that's a queen
Old 02-14-2011, 03:06 PM
JMatta's Avatar
Those Pirellis must be like hockey pucks! My friend bought an '02 Box S, 15k miles, with P Zeros...the tires were so hard you couldn't stick your fingernail in the tread. He replaced them shortly thereafter (Michelin Sport Pilots) and the car drove as different as night and day.
Tires beyond five years are definitely suspect and in need of renewal.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 02-14-2011, 05:46 PM
turboflyer's Avatar
Unless it is a grocery getter they probably need to go. Just make sure to check the news one so you dont start off with a two or three year old tire. Shop tried to sell me an 08 tire. Told them no thanks. Waiting for the new batch to arrive.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 02-14-2011, 06:37 PM
Mine came with the original bridgestone S02 and all 4 tires have inner threads separated (306 degrees crack) due to age .
Mine is 02MY.
Old 02-14-2011, 07:19 PM
srg srg is offline
If you are going to replace them anyway, make sure you get "full use" out of them before they are removed!
SRG
Old 02-15-2011, 06:18 AM
Author of "101 Projects"
Wayne 962's Avatar
SRG
Heh, funny. We did this at Willow last time the Super Boxster was out there. We had a bead separation on the tire, and needed to get them "warm". I could only think of one way to do it quickly!
-Wayne
Old 02-15-2011, 12:57 PM
Originally Posted by Wayne at Pelican Parts View Post
5 years is a good conservative life for tires
+1.
The consensus at a recent PCA mechanics panel I attended was tires should be replaced every 4-5 years, regardless of mileage.
Old 02-15-2011, 04:38 PM
You are correct & most tire manufacturers warrantys expire after 5-6 years of the sale date. Check your owners manual & tire warranty for more info. That being said properly stored tires have a nearly indefinite "shelflife" mainly if protected from UV light which dries out the tires much like the sun dries out our skin. Clean the tire sidewalls & tread the best you can & inspect closely for any surface cracking especially near the wheel & between the tread blocks. Cracks larger than 1/8" indicate the rubber is drying out enough to lose traction & pliability & you should evaluate your intended usage of the tires: unsuitable for high speed cross country touring / suitable for display in a car show etc.
Old 02-15-2011, 04:59 PM
Boy, it has never occurred to me to check the age of new tires! Of course, makes perfect sense! How does one confirm the manufacturing date of the "new" tires? Is there a date code on them somewhere?
Old 02-17-2011, 04:38 PM
Find the DOT number on the tire sidewall. It starts with "DOT" and will have 10-12 digits. It might be on the inner sidewall so look there if you can't find it on the outer sidewall.
The last two digits are the year of manufacture, e.g., 10 would be 2010.
The two digits precediing the year are the week of the year that the tire was manufactured, e.g., 12 would be the12th week of the year or somewhere around late March, 51 would be the end of December, and so on.
Old 02-17-2011, 04:49 PM
turboflyer's Avatar
My tire shop just called today and my new bridgetones are in. They were back ordered due to a production stop. Originally tried to sell me a an 08 and 09 production set. Mine will be on the full 5 or 6 and I wanted the full use. Cant wait. Tired of old tire sound.
Old 02-17-2011, 06:23 PM
youngone's Avatar
Thanks for all that have replied. Replaced the original 18" Pirellis today with Continental DWS all around. Like a whole new car, smoother handling and a ton less road noise. Really remarkable in that the tires I replaced were 50% plus tread. It was the age of nine years that made the difference and perhaps the manufacturer.
Old 02-28-2011, 06:08 PM
