-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Got alignment after installed struts (http://forums.pelicanparts.com/boxster-cayman-forum/592160-got-alignment-after-installed-struts.html)
WhipE350 02-16-2011 05:45 PM
I got my 4 wheel alignment today at a great Indy after I had installed 4 Bilstein Shocks (HD Front, Sport Rear). I wasn't aware that the camber in the front was controlled by the strut mount bolts. I'm sure somewhere I read it but had forgot. When I put on the front struts I didn't weight the wheel carrier since I didn't loosen the wishbone bolt on the frame...however I think if I had, the shock mount would have not been so far off, but still if you look at this picture I probably still would have made sure the bolts went back where they were from the factory...check out out how far they moved them to get a -0.5 camber! (2000 'S')
BTW the car drives great now!
http://forums.pelicanparts.com/uploa...1297907039.jpg
Wayne 962 02-17-2011 02:29 AM
Yup! Here's a little primer on Boxster alignment: Pelican Technical Article: Boxster Alignment Principles - 986 / 987
-Wayne
WhipE350 02-17-2011 03:30 PM
Thanks Wayne, yup I've read almost all your articals...that's how I've been able to enjoy working on the box so much. I just found it strange that new shocks would effect the factory setup so much.
Wayne 962 02-17-2011 05:22 PM
They shouldn't - something else must have changed...
-Wayne
