Resident Electrician
Mike Bellis's Avatar
Boxster axle flanges at 108mm?
Does anyone know if someone makes a 108mm CV transmission flange? I would like to use 930 CV's on a Boxster transaxle. I would also consider a 100mm to 108mm adapter.
Thanks, Mike
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 06-19-2013, 07:10 PM
OK... A little research and it looks like the 6 speed tranny is 108mm. I have a 5 speed. Can anyone confirm if the flanges are interchangeable? I found a post on another forum that states they are.
Past Projects:
Old 06-19-2013, 08:01 PM
