1999 Boxster - Horn Fuse Blown
Last summer I experienced a problem with my horn fuse blowing. Someone mentioned that there are rubber boots on the air bag mounting plate (not sure if right term), and that over time, due to heat (Texas summers), the mounting plate rubber boots thin, and can cause a short.
Anyone have a similar experience.
Thanks in advance.
Greg
Old 02-13-2011, 12:02 PM
Author of "101 Projects"
Wayne 962's Avatar
That's correct, although the failure of these should cause the horn to come on, not necessarily blow the fuse. I did have the same problem on my car - the problem was a stuck horn. The horn when it gets stuck begins to pull a lot more current and will blow the fuse repeatedly. The horns are VW horns, and are incredibly cheap (something like $12 each). They are located right behind the front bumper and are really easy to get to once you remove the bumper.
Article on removing the bumper: Pelican Technical Article: Boxster Front Bumper Removal - 986 / 987
Link to the horns in our catalog: Porsche Boxster Gauges and Miscellaneous - Page 1
Hope this helps,
Wayne
Old 02-13-2011, 12:16 PM
Wayne,
Thanks for your timely reply.
'Really appreciate your assistance, both your reply, and the valuable resources your enterprise provides.
Regards,
Greg
Old 02-13-2011, 12:30 PM
Wayne,
'Sorry to bother you..
Are you suggesting that the horns could be causing my fuse to blow?
Or should I start with air bag mounting plate?
Old 02-13-2011, 08:20 PM
'Found this comment under "Reviews" section for air bag mounting plate part:
By Mark O., submitted September 21, 2010
Comments: Common problem with 996 is the rubber gromits on the frame of this part degrade and the horn will beep on bumps and stops. I tried to reinforce the gromits with silicone and that worked for a couple of months but then the problem restarted. Ordered this part that includes new gromits and the problem is finally and permanantly resolved.
Thanks,
Greg
Old 02-13-2011, 08:33 PM
Wayne 962's Avatar
Originally Posted by Greg986 View Post
Wayne,
Yes, the airbag mounting plate should not cause the fuse to blow on the horns. I had a problem where my horns were stuck and were blowing fuses. I'm quite sure that's your problem - they are so cheap, I would replace both while I'm in there.
-Wayne
Old 02-13-2011, 09:36 PM
Wayne,
Thanks again. 'Replaced the air bag mounting bracket this past weekend - solved the problem of horn going off. (Building security notified me that my alarm was going off!)
With the benefit you your book, I mustered the courage to tackle challenge of removing the air bag, and replacing bracket.
'Horns in near future, then on to the window regulator...
'Appreciate your assistance.
Greg
Old 02-21-2011, 08:08 PM
