Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Need a DIY for replacing the oil fill tube
I've been searching around for a vacuum leak after I got a CEL with the 1126 code and I'm almost positive it's coming from the middle of the oil fill tube under the center section of the intake system. I can hear some hissing at idle and when I press down gently on the exposed part of the oil fill tube as it disappears under the intake the hissing sound gets louder and the motor starts running rough.
So if there's a DIY someplace with a bunch of pictures I could sure use the help.
Old 03-03-2011, 09:16 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
In the shop at Pelican
Jared at Pelican Parts's Avatar
What year? Boxster or Boxster S?
Old 03-03-2011, 12:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
harryrcb's Avatar
there are a couple of vacuum lines that run either over or under the oil refill tube that connect on the bottom of the rubber connector (which get brittle with old age) of the front intake manifold. Sound like you might be tugging on that tube and that would certainly make the engine run rough. Look for it it's a small tube
Crazy Austrian
http://www.ws-ab.com
Old 03-03-2011, 07:57 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
See the coolant tank replacement article for information on disconnecting the oil filler pipe: Pelican Technical Article: Boxster Coolant Tank Replacement - 986 / 987
And then see Figure 13 of this article: Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines101 Projects for Your Porsche Boxster & Cayman
Coming in 2012:
• 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997
Old 03-03-2011, 09:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
You can also check by removing your oil filler cap in the rear trunk. If you remove the cap and there is no or little change in the running of the engine, then you have a leak in the tube (most likely).
-Wayne
Coming in 2012:
Old 03-03-2011, 09:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
The car is a 2000 S Tip. I've already done the AOS oil cap test and that seems OK. And thanks Harry, for the tip about a vacuum line. I should probably hold off simply ordering a new oil fill tube until I can see the actual problem. I'm thinking about taking the car to the independent shop in Little Rock instead of attempting to fix it myself. The accessibility looks pretty tight in there and I'm worried I'll mess up the job.
Old 03-04-2011, 04:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
It's probably a good idea to have it looked over before ordering parts. I thought mine was split but it ended up that the joint where the two pipes meet in the middle was leaking. I replaced the spring clamp with a worm gear type and that fixed the problem.
2000 2.7L
Old 03-04-2011, 06:39 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
2000 2.7L
How did you access this area? Is it necessary to remove the entire intake manifold system or can you get to the tube if you take out the throttle body and the middle couplings between the manifold halves?
Old 03-04-2011, 10:20 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
On my car I thought I had a split in the flexible accordion area in the spot between the middle joint and the trunk bulkhead. I replaced that part only to see seepage at the middle joint. After replacing the clamp with a worm drive type all is good. The middle joint area is right on top of the engine and doesn't require removing anything but the engine cover. The section that goes to the trunk is fiddly to get at but you can also do it without removing anything. The section that goes from the middle joint to the engine I'm not sure about. Mine is still the original part. The main thing that's tricky is getting those dang spring clamps off.
Old 03-04-2011, 12:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
I got the car back from the shop yesterday. They had some trouble finding the intake leak. They could hear something when they moved the rear (accessible) section of the tube by hand and it sounded like under the center of the engine but they said the leak actually came from the accordian section near the rear firewall. They showed me the old tube and there was deterioration but I'm not totally convinced that was the only problem based on how distinctly the sound seemed to come from another spot. No codes so far and the car runs fine so they could be right. The bill was a little over $300, which I'm happy to pay if it fixes it.
Old 03-16-2011, 04:42 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
