Guest
Posts: n/a
what grade oil do you recommend for north Florida? I have a factory replacement 2.7 and want to start changing my own oil. had the dreaded IMS failure and want to protect against a repeat!
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Oil Change |
Author of "101 Projects"
I like to run thicker oils full year in the hotter climates. Something like a 20 or 15 weight would be fine. Or, simply go with the factory recommendations. The one thing I would be sure to do is to make sure that you change the oil every 3000-5000 miles max. The newer oils don't have the same amount of ZDDP anti-wear components in them, and cause premature wear (which may contribute to the infamous IMS problem).
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I just purchased 101 projects for boxster and wanted to know a cheaper alternative for 0w-40 for my 2005 boxster. I have been using 0w-40 since I bought the car and didn't know if I could use anything else because its recommended by the porsche. I would not mind using some other oil as long as I don't lose the performance and damage the engine. Changing every 3000 to 5000 miles as recommended by the book can be fairly costly if I continue using 0W-40.
Thank You |
Hi there. You can probably use any oil in your engine, and it will be perfectly fine. Modern oils are so much better than the ones manufactured in the past that there aren't many differences between them. If you're in a warm climate, then I would run a heavier weight Castrol oil or something similar to that. But in general, frequent oil changes (every 3000-5000 miles) are way more important than the actual brand, or type (synthetic versus organic).
-Wayne
Mike is right (again), which is why I try to stay away from those debates.
Change your oil every 3,000 - 5,000 miles, and it probably won't matter what you put inside.-Wayne
Thank You
Look at amsoil.
