TWO WARNINGS!
FIRST: There are no instructions given for removing the plastic surround for the inside door handle. On the top rear of the cover is a plastic lip or clip. You need to pull the bottom of the cover out a bit and the push up the rear to clear that clip. Sadly, I didn't find out until the freshly broken end flew past my head. I was able to put it back on. But, I'm going to have to get another one. SECOND: On my 2000, the screw inside the glove box in Figure 1 marked with a red arrow is not a screw at all. But some sort of plastic push rivet or had very soft threads that stripped. I have no idea how that was really supposed to come out. I had to cut it out. I reassembled without it for now. __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Door Panel Removal / Boxster Mirror Switch Replacement - 986 / 987 |
Author of "101 Projects"
Thanks for the feedback Jay. The car in the photos is a 2000 Boxster, so I'm not sure where the differences lie. The clip should simply snap off of the door handle, I think you can do this with a soft plastic spatula. As for the screw inside the door, it's definitely supposed to be a screw. The fact that it wasn't means that a previous owner or mechanic who was sloppy was mucking around in there.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
