2002 Boxster S starting issue
Car has 145000 miles. It start right away but shuts off when hot (180 ), it doesn't matter how much I try, it wont start back. left it overnight but still no sign. try to push start which worked. it start now and then but shuts off again.
I read about crankshaft sensor can be the reason, but not sure. Does anybody have any idea from where I should start? Any help will be greatly appreciated. |
Porsche's Love-em Live-em
If available check for fault code's.
If not, I would try another crank sensor. Check out [try another] the main DME relay and fuel injection, Ignition, Ox, combo relay relay. If no start again send the ECU off to get checked out? |
I will try |
Administrator
Starter System Troubleshooting -Dmitry |
I have the same problem. Just cranks but will not fire. Help!
Sent from my SM-N920V using Tapatalk |
I replaced the camshaft position sensor, so far it start every time. I haven't drove it yet, but I did start and let it run for 20-30 min, and restart again, morning, night, hot or cold. it seems to be working fine.
thanks for reporting back
It is all the people who post answers need to keep them doing it.
