Author of "101 Projects"
Wayne 962's Avatar
Torque Spec for ignition coil screws...
What is the torque used to tighten the coil pack bolts on a 06 Boxster? Your book, 101 projects is great! Thanks ,Roger Lenkin
Hi Roger, the factory documentation shows that these bolts are sized M6, and should be tightened to a value of 10 Nm (7.5 ft-lbs), which is not a heck of a whole lot. Be careful not to overtighten them, or the bolt / screw might snap off.
-Wayne
Old 04-23-2011, 01:39 PM
