-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Disconnecting battery makes the alarm go off? (http://forums.pelicanparts.com/boxster-cayman-forum/601937-disconnecting-battery-makes-alarm-go-off.html)
Ray (guest) 04-09-2011 01:11 AM
When I disconnect the battery lead the alarm goes off, it stops if I reconnect the battery, I'm removing the door trim to get at the window winder and want to disconnect the battery in order to remove the airbag.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Battery Disconnect Switch / Battery Buddy Installation - 986 / 987
Wayne 962 04-09-2011 01:12 AM
Hmm, this makes no sense to me, when you disconnect the battery, the alarm *must* stop, if it's a factory alarm? Can you give more details? I'll copy this question to the forums so that you can reply there.
- Wayne
JMatta 04-09-2011 07:15 AM
Wouldn't the battery supply power to the alarm? Sounds like aftermarket, with a reserve power source of some sort.
Tinsby 04-09-2011 09:25 AM
Odd
I agree of course, that thing is getting voltage from somewhere other than the main battery. I have never heard of this on any car not just yours.
You could of course just let the thing bleat away until it dies, trust me it will eventually die! Just put the car in the garage, unhook your battery and let it holler.
Go out for lunch and when you come back you can get at that window regulator!
Good luck,
Tinsby
randy_k 04-09-2011 09:43 AM
Agreed, Sounds like an after market alarm. Since thieves are known for disconnecting the battery to keep the alarm from going off. Some after market alarms and a back up battery. That is usually mounted under the dash, somewhere. See link below,
http://www.pythoncarsecurity.com/products/Accessories.aspx
Randy
intakexhaust 04-12-2011 10:20 AM
OEM or aftermarket alarm? No OEM alarm on your car described would sound after disconnecting the battery unless..... a second 12 volt battery back-up is hidden -OR- you have an aftermarket alarm with a battery back-up.
nosnow4pc 04-12-2011 12:38 PM
If you are in Europe I think there is a factory alarm option with tilt and battery backup. I remember someone in my local group talking about how annoying it was.
