Blocked Drains during the rebuild
While rebuilding car today, I found a fair bit of water on the floor , behind one of the seats (not the ECU side luckily. I pulled the carpet up and the sponge was sodden.
I'm guessing the drain hole is blocked but where is it ? and whats best method to clear it. Thanks guys... Other than that the car is coming on great, only arch liners and undertray to go and it's about done. more pics on the way |
Crazy Austrian http://www.ws-ab.com |
CEO, Pelican Parts Inc.
Or, they might be clogged in the front, which is where mine are always clogged. I have an article coming out on carpet drying and replacement. In the meantime, you need to remove everything that holds down the carpet, lift it up and then put some electric heaters blowing on the underside for a couple of days. It *will* dry out, but it will take some time.
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman Coming in 2012: • 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997 |
Thanks guys, cant find the front drains, or see where they exit the car though ( front or back )
That's a good link, the drains problem is a big one on the Boxster. Both of my cars have had issues with clogged drains.
-Wayne
Thanks Guys, very useful, will attend to that tomorrow
