matt (guest)
Guest
Posts: n/a
G'day,
Do you have any images of the other end of the line to the crankcase? Where does it attach? Is there a vent line associated with this line has a spring inside it near the crankcase attachment?
Sorry, disregard the image request, I found one in your online parts catalogue 996-107-047-51-M100. I am trying to work out how this part, with a small vent? port works.
Cheers, great site & forums!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Air / Oil Separator Replacement - 986 / 987
Old 04-17-2011, 07:42 PM
mattatk's Avatar
Question on Boxster Air Oil Separator
I was curious about the connector to the crankcase for the AOS (part number 996-107-047-51-M100). Mine has a small spring loaded valve on it (possibly a vent purge for overpressure?).
My connector "vent" is covered in old oil & has covered part of the crankcase (lower left front side of engine). It appears to be quite tacky & old though.
Should this connector vent/purge oil like that?
Cheers,
Matt
Old 04-17-2011, 08:42 PM
The Positive crankcase ventilation valve does contain a overpressure valve opening pressure is 180mbar +/- 20mbar. I wonder if this valve becoming clogged/nonfunctioning contributes to AOS failure due to excess crankcase pressure??
Old 04-18-2011, 10:21 AM
Author of "101 Projects"
Wayne 962's Avatar
Wow, what a great thought there, I have never thought about that. Let's see, if the purge valve shown here gets stuck, then if there is a positive pressure from the crankcase, it will indeed get flowed right back to the air oil separator. Now, I would assume that if the separator can handle vacuum, it can handle pressure too, but I'm not sure. Also, the pressures might be higher than the vacuum. This is a good topic worth thinking about - perhaps a stuck valve here is indeed contributing to the air-oil separator failure issues.
-Wayne
Old 04-18-2011, 12:54 PM
I'm going to see if I can install a new pcv valve thru the firewall & see if it makes a difference.
Old 04-19-2011, 10:52 AM
wishful thinking, if only it were that easy.
Old 04-19-2011, 01:44 PM
rcarpen22's Avatar
How much, if any, of this emissions equipment do Boxster spec racers remove from their cars?
Old 04-20-2011, 06:59 AM
Wayne 962's Avatar
It depends. I think that most remove it all and then just ignore the check engine lamp that results. Removing some of the items though might cause the fuel injection system to freak out, so you might need a "Boxster Spec" software upgrade to force the computer not to worry about silly things like emissions on the racetrack.
-Wayne
Old 04-20-2011, 08:33 AM
rcarpen22's Avatar
Black electrical tape works for the cel :-)
Old 04-22-2011, 11:36 AM
Wayne 962's Avatar
True. On the early cars, you can pull the bulb. On the later cars (I think 2001 and later), the electrical tape works well.
-Wayne
Old 04-23-2011, 01:44 PM
rcarpen22's Avatar
I replaced my AOS this morning. It was a lot harder for me to get the old one out than it was to get the new one in. My one little piece of advice is to remove the small 10mm bolt holding the electrical connectors in front of the AOS (looking in from under the car). It was a lot easier to get to after that. Also, I had to use a big screwdriver to get the lower vacuum line off (purple arrow in Wayne's book).
Old 04-23-2011, 07:15 PM
Wayne 962's Avatar
-Wayne
Old 04-25-2011, 01:04 AM
Wayne, I will be tackling this project soon...I have your book (couldnt do stuff without it and my bentelys) are there any 'tricks'- process steps to help me on this DIY? I have the craftsman clamp pliers (they are a godsend with the porsche clamps)...other than that is it just a follow along and be patient? I just would like to know since you and many on this forum have tackled this in the past if there any little pointers that you could pass along to keep me out of trouble aka 'see I told you to take to the dealer now it's going to cost more since you messed it up' (wife's reply when I try to do more than she thinks I'm capable of) LOL
Thanks in advance
m2
Old 04-26-2011, 07:20 AM
mattatk's Avatar
Has anyone had any more info on the connector/valve part 996 107 047 51? I am still trying to work out how it fits in to the AOS equation.
Old 11-16-2011, 09:03 PM
Inquisitive user
randy_k's Avatar
Illustration, 104-10 shows how it fits in. It appears to go to the block. I've never read of anyone replacing it though. I didn't when I replaced my AOS either. I would guess, its a PITA to get to as well.
Randy
http://www.porsche.com/all/media/pdf/originalparts/en/E_986_KATALOG.pdf
Perpetual change. It will happen!!!
Old 11-19-2011, 10:38 AM
mattatk's Avatar
I am curious as there appears to be a fair bit of oil residue around the connector, I'm guessing it has bled out the valve end. Mind you that could have been the valve doing it's job?
Old 11-19-2011, 11:37 PM
Reviving this thread
My AOS blown again after only 2500 miles. I'm wondering about the PCV valve. I got the same symptoms with oïl residu starting from the PCV valve and wondering if its still working. Anyone have change it? Any good way to change it?
Later
Chris
Old 04-14-2013, 08:15 AM
