-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Inside door handle is loose (http://forums.pelicanparts.com/boxster-cayman-forum/603534-inside-door-handle-loose.html)
Mark (guest) 04-18-2011 02:19 AM
My driver's side handle is loose. It "drops" away from the door and causes the window to lower the 1/4" in preparation for opening the door. If I push the handle back up into place, the window goes up into the frame. Is there a spring adjustment to tighten the handle?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Door Lock Mechanism / Boxster Door Handle - 986 / 987
Wayne 962 04-18-2011 02:19 AM
I'm not aware of any adjustment in there. I think there's probably something broken where it attaches. It's pretty easy to remove the door panel and take a look, I would try that. I think you'll probably find the handle support broken.
- Wayne
ProjectM96 06-21-2011 08:20 AM
I have the same problem. As a temporary fix, I used Velcro to hold the handle back in place so that the window goes all the way up after closing the door.
There is a very little U shaped metal piece that broke off the inside of my handle and that is when the problem started. I could not figure out where the U shaped metal piece came from exactly or how to fix it.
