Radio Amp Problem (Pics)
No Radio reception, so I removed A-Pillar cover to scheck the amp. Pictures show what I found.
I believe the 'Tab' in my hand should be attached to the screen..but where .?
Is it broken (by the ham fisted windscreen installer perhaps) or is there a fix to this..
Old 04-29-2011, 02:14 PM
Wayne, Screen was fitted before I got the car. The original was all over the floor on purchase and the replacement installed by the seller. There is an element running through the screen but sadly it looks as if the installer broke the tab off.
With no original to look at, I have no idea whether or not I need to get it changed again..
Old 04-30-2011, 02:55 AM
turboflyer's Avatar
You may have answered your own question. From the looks of where it is routed doubt you could attempt a fix. Might be able to get a small loop type antenna and adapt it to the wires.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 04-30-2011, 04:40 AM
