ims retro cam lock
Are the tdc and and cam lock just for checking after the job? There is no mention of tdc before extraction or installation. As such, is the cam lock only to check allignment. Not much on this in the instructions...that I saw.
Thanks, Joe |
Inquisitive user
Randy 5. Put engine at TDC, and lock out the pulley so the engine cannot turn over. 6. Pull cam plugs and make note of position. It is recommended that the cams are locked out using factory cam timing tool. If two sets of cam tools are available, it is possible to modify the tool to allow both sets of cams to be locked, even with the engine in the car.
Perpetual change. It will happen!!! |
Platinum Member
Yep, lock crank at TDC, check cams don't move, lock them if possible.
Author of "101 Projects"
Since for my "set screw" method, you need to find a good spot where the screws will hold, I don't specify putting at TDC, only checking later on after. This is if you don't lock the camshafts.
Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06) -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
