-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Convert spring rates? Math test! (http://forums.pelicanparts.com/boxster-cayman-forum/607868-convert-spring-rates-math-test.html)
The Glademister 05-10-2011 12:02 PM
Okay, all you math wizards, let's see if you can convert these metric spring rates for some coil-overs we bought for the Boxster...
front 6.0 kg/mm
rear 8.7 kg/mm
Good old pounds would be something that I can process :confused:
randy_k 05-10-2011 12:15 PM
1 kilogram = 2.20462262 pounds
So 6kg=13.22773572 pounds
and 8.7kg=19.1802216679 pounds
Is that what you where looking for?
Randy
PS, Google is your friend. (-;
The Glademister 05-10-2011 12:20 PM
Actually found something a little different...
Re: spring rate conversion
by Robert Fogt on 03/16/05 at 12:40:09
Springs are rated in pounds/inch in the U.S., and Newtons/millimeter elsewhere. I have not seen kilograms/millimeter before, but the conversion will be easy enough.
1 pound = 0.45359237 kilogram
1 inch = 25.4 millimeter
0.45359237/25.4 = 0.0178579673228346
The conversion factor is 0.0178579673228346
So, to convert lb/in to kg/mm you multiply by 0.0179 and to convert kg/mm to lb/in you divide by 0.0179
So that would mean...
Front 335
Rear 486
...which sounds about right.
